Old 29-04-2006, 09:14
wimdepim wimdepim is offline
S12oc Newbie
wimdepim is an unknown quantity at this point
Default need some help
hey everybody
i have a problem
i want to buy a better turbo
but down here(belgium) is a problem very expensive items
so if someone get tell me what i need to change turbo fuel exhaust ? i would like about 200-220 bhp in the car
and if one of you makes the deals and send it to me i would really be glad
i am running at the moment with a stock turbo with more boost, closed the return fuel line a bit for more fuel pressure and installed a small intercooler from a mercedes vito cdi and got about 175bhp at the moment
i hopesomeone can help me
thanks mates
Old 29-04-2006, 10:04
For 200-220bhp at the flywheel your easiest option would be to fit a t25 (standard spec on the s13). The simpest conversion includes using the same turbo gasket,the s13 downpipe and the s13 oil return line. You will need the s13 3 bolt flange that bolts onto the t25 compressor outlet aswell and then adapt it to the shape of your pipework directions with a hacksaw and maybe a aluminium welder.
Running at 15psi your should see around 220bhp aslong as you have a healthy engine with decent filter and exhaust system
Old 29-04-2006, 19:23
after having my fuel pressure reg fook up and give me near full pressure 60 ish PSI) at the injectors, is blocking off the fuel return a good idea???? i found it has massive over fuel.
Old 29-04-2006, 20:03
S12oc Newbie
just got it running again it was rolling on 3 piston and had to change airflowmeter sparkplug wires 1 sparkplug and clean it i'd just replaced sparkplugs last week
and now i was bussy i installed an intercooler as well (broken last race)
i replaced airfilter(big race filter) 2 weeks age could it be that it run bad and needs adjustments?
i saw a adjustement crew on the airflowmeter and don't now what it does!!
just got an offer for a t25 of a 300zx 88-89 version
lots of work ?
Old 03-05-2006, 16:39
S12oc Newbie
ok found a turbo a t25 from a rover 220 turbo with 65tkm(40tmiles)
for 250euro (235$)
now i just need to now if i have to change exhaust (bigger or not) and fuel system (just close return fuel line or changing other parts)
Old 03-05-2006, 18:03
can you not just find a s13 t25 and downpipe as pukka surgested surely thats the easiest route and then make yourself up a 2 1/2" exhaust with performance silencer if your going for 200+bhp,personally i would unblock the fuel return
