Old 21-06-2006, 11:24
johnny johnny is offline
johnny is an unknown quantity at this point
Default High tickover
My Silvia is suffering from the dreaded high tickover but only when warmed up, cold is around 800 rpm and warm around 12-1300 rpm. After searching through the forum it seems this could be caused by an air leak. Is there any way to check this is the case by removing and blocking a pipe etc. On mk1 Escorts I've had in the past we sprayed wd40 around areas we thought might be leaking air and the tickover would alter if this was the case, would this work on a more modern car such as the Silvia?
Or could it be something else due to it only doing it when warm, a cold start sensor not turning off or bad connection? Or is there simply a screw for altering the idle when warm.
Sorry for all the typical newbie questions
Old 21-06-2006, 13:09
datdrift's Avatar
datdrift datdrift is offline
there is a screw on the inlet manifold for altering the idle, but it sounds like one of your sensors is not working, try giving the connectors a wiggle and see if it makes any difference?
Old 21-06-2006, 14:25
Like you said could be the Choke sticking open !!!
Old 21-06-2006, 20:20
wacomuk's Avatar
wacomuk wacomuk is offline
you can check for leaks using a gas, less messy than wd40
there is a sensor on the inlet manifold side that gets blocked this can caues high or low idle
Old 21-06-2006, 20:49
Thanks for all the replies, I'll have a poke around the engine bay at the weekend.
Old 22-06-2006, 01:02
Its probably an incorrectly setup throttle position sensor
