Old 29-12-2006, 22:57
Oscar's Avatar
Oscar Oscar is offline
Default need a few bits of advice
well here goes, sort of got fed up recently with the car, exhaust rattling, overheating, squeky brakes,rear diff leaking... and not holding owt above 7psi, oh and it acts like its got a flat battery sometimes tho the battery and starter and alternator have been tested... any ideas?
well i plan to repsray it matt black, get an intercooler,
how much for a decnt exhaust, suppliers?
springs?
sorry for the rant but this car is truing into a money pit and my partner hates it!
Old 29-12-2006, 23:09
Originally Posted by morkai
this car is turning into a money pit and my partner hates it!
sounds like you need to get a new other half. Only joking.
Most performance or classic cars are money pits. Its crazy how much it costs to keep a car going .
Is the battery the correct battery for the car with the correct cranking amps?.
Does the engine burn a lot of oil?
It probably needs a new thermostat for the overheating problem.
Old 29-12-2006, 23:16
Oscar's Avatar
Default well....
well i sorted the overheating prob
it used about a litre of oil in 2months, which i thought wasnt too bad, ive been told the battery is the right one, sometimes wen cold or hot u turn the key and all u get is a click or sometimes it struggles but mostly a click
Old 29-12-2006, 23:26
sounds like the starter motor is nackered to me or the connections to it are poor, the clicking is the solenoid on the starter sticking or not having enough power to throw it out
what was the overheating problem?
Old 29-12-2006, 23:33
Oscar's Avatar
Default well
it was a small split in the rad causing an air lock, this then split even more, causing it to spit several litres on the flour lol, sorted now tho, its just getting on my nerves, want a new exhaust after the last back box burnt my bumper,
were vis the starter motor on these?
Old 29-12-2006, 23:56
Oscar's Avatar
Default one other q
wen i switch to fmic, wat do i do with the breather that comes out of te throttle body?
