Old 01-08-2007, 12:05
Conkers's Avatar
Conkers Conkers is offline
Default Urgent..CA18ET vs CA18DET injectors...
My CA18ET engine has injectors that were measured at 289cc
CA18DET injectors are rated at 370cc. This much is general knowledge.
Now to my little problem...
Does anyone have a picture of a CA18DET injector? I bought a set of used
S13 CA18DET injectors off a guy online, but they dont look anything like the ones that I took out of my CA18ET!
So if anyone has pictures of what I need then I would be grateful.....
Questions:
Do both kinds look the same?
What are the part number of the CA18DET injectors?
Are CA18DET injectors a barb fitting, or come pre-fitted with a short rubber pipe like the CA18ET injectors?
The ones I had sent to me look like oring seals on both ends....
I'll get some pictures up of standard CA18ET and te ones I had sent me, so say from a S13 CA18DET.......
Help me obi-wan...
Conk.
Old 01-08-2007, 12:21
det ones are not barbed, they are o ring and measure 10mm, the et ones fit 8mm hose.
Old 01-08-2007, 14:17
Conkers's Avatar
Ah.... so when everyone says "fit DET injectors, they are 370cc" they actually mean.... "fit DET injectors AFTER you have made a fuel rail"!
So do you know if there are any direct replacement 370cc injectors that will fit directly into the ET manifold and have a barbed fitting at the top? Or is making a fuel rail my next project?????
Or am I going to have to be a hero and rodger an 8mm fuel hose onto a 10mm injector with hose clamps and hope for the best! I mean... petrol, it's not that flammible it it leaks right??!!!
Conkers.
Old 01-08-2007, 14:20
Don't you have to do both? I've got the injectors but I've not done anything with them yet
Old 01-08-2007, 14:33
i had a rail made .would'nt 8mm force over the 10mm injectors ?
Old 01-08-2007, 14:51
Should be able to squeeze the fuel pipe over the 10mm end. I would be tempted to flare the fuel rail ends up a bit and use a 10mm pipe. All a question of whether it will leak though when the highest fuel pressue will be on a tonk at 20psi boost, which is approx 55psi fuel pressure.
