Probably a stupid question lads but i have the possibility of getting a skyline r32 diff fitted with a 1.5 lsd, can i just fit the whole r32 diff to the s12 subframe or is it necessary to build it into the s12 diff casing?
cheers |
you'll need build it in an s12 casing kid. you'll need the six bolt inner cv joints to match the diff of the liner and 2 rh drive shafts from an s12. one has to be shortened by bout 8mm to fit on lhs of silvia. bit of work but be worth it if 1.5 in good nick.
if you change your mind would you sell the diff itself????
i havn't bought it yet, but if your interested its a kaaz and is going for 500euros ono, im going to have a look at it at japfest next week and will decide then if i can afford it or not, ill send you on the phone no if i dont get it.
BTW, do u still want my old s12 box? Last edited by terry; 29-08-2007 at 00:45. |
