Old 03-03-2008, 19:26
Oscar's Avatar
Oscar Oscar is offline
Default yay! Another problem!
ok problem number 2, i think my gearbox maybe fubar, its an auto, when its cold, and sometimes when its warmed up, 2-3 and 3-overdrive it dosnt want 2 change, revs go up speed only slowly increases, and it feels like its gona hit 8k rpm before it wants 2 change, also when its cold if u put it into drive it stalls like if u bring up a clutch, the weird thing is when the problem occurs the voltage rockets up 2 around 15.7-9 v.
Old 03-03-2008, 19:36
to start with, check your transmission fluid, i thought mine was fecked after it had been up on axle stands for months, i started it up, put it in reverse and drive, but it wun't move, i toped the fluid up and worked the gear change back and fourth for about a hour, until it started to creep forwards, it did eventually right itself.
Old 03-03-2008, 19:39
Oscar's Avatar
tried checking the level, but the dipstick would not budge! Me and niki pulling did nothing, leaving 2 soak so wd40 round it
Old 04-03-2008, 19:18
check the vacuum pipe from the inlet fanimold. If still no joy email Silviagod
Old 04-03-2008, 19:36
Oscar's Avatar
cheers will do, the fluid level was nothing 2 write home about, very small top up, il do another vacum check,
Old 05-03-2008, 15:45
Oscar's Avatar
would say a low oil level/knacked diff be 2 blame?
Old 22-03-2008, 17:10
has it got an intercooler on it oscar ?
Old 22-03-2008, 17:12
Oscar's Avatar
not yet, was going 2, but this problem bin keeping me busy
Old 22-03-2008, 18:45
Oscar's Avatar
well the ecu is dry now, and seems 2 run a lot better, but stil seems down on power, but at least its running ok now
Old 22-03-2008, 22:52
zxocmars zxocmars is offline
Well i suppose, in a way I was right in my earlier post
DAMP
