Old 19-05-2008, 22:29
carty672 carty672 is offline
carty672 is an unknown quantity at this point
Default smoke at idle
Hi all, new to club and silvia ownership, just a quick question car runs fine no smoke at all when under load or at start up but if youve been driving at normal speeds using the turbo and then leave the car to tickover for about 2mins it will smoke like crazy! until you drive off when it will clear up almost instantly, im thinking turbo seals? any ideas, thanks.
Old 19-05-2008, 22:55
carrottop carrottop is offline
carrottop is an unknown quantity at this point
Hi mate im a mechanic and see this alot when the turbo seals have gone especially in r5's which use the same t2 turbo
Old 19-05-2008, 23:23
yep as above turbo seal
Old 20-05-2008, 10:17
SST_Ti SST_Ti is offline
S12oc Newbie
SST_Ti is an unknown quantity at this point
My Scimitar SST was doing this (same engine as the S12). A temporary fix that cured it for me was to turn up the idle a little bit (from 750rpm to just under 1000rpm). The turbo was replaced 30k miles ago by the previous owner so I'm loathed to do it again already.
Old 20-05-2008, 11:00
Thanks for the quick responses, looks like i better get a rebuild kit! it cant be that hard or can it?
Old 20-05-2008, 19:37
diy rebuild kits are not worth the aggro. they rarely work
