Old 08-10-2008, 19:40
alundra alundra is offline
Default Help for fitting my EBC
Hi,
Finally i'll save enough money for an EBC.
I need to know where can i attach such wire (specially the parking cable (ground or 12v?) and ignition (ACC wire or starter wire?)
Here a pic in the manual:
BCU+ is the name of the EBC.
Thanks.
Old 09-10-2008, 20:03
I found myself how to fit the wires .
Now I need to fit this:
By my mouth, seems easier to push air left to right; seems because not like pcv valve which block the air.
Thanks.
Old 13-10-2008, 23:08
Finally I founded how this piece fits like the GReddy profec B one.
The settings is hard to get.
Can you give me what number must be for my set up: large air filter, front mounted medium size intercooler, 2.5 piping, cold spark, stock healthy T2, 2.5 exhaust line.
My desired boost is 12 psi.
I need:
-Gain in %: ?
-Start boost: ?
star boost is at what psi the the wastegate begins to open, example if you boost setting is 10 psi and your start setting is 2 psi; the wastegate will begin to open at 8 psi
Thanks...
Old 14-10-2008, 19:17
Ok i set 75% for the gain, and 10 psi for start boost but need to be tuned.
Something strange too: i read 12 psi on my boost gauge and 14/14.3 range and my EBC.
Which one to believe? (same boost source)
Hope it isn't an one person thread...
Old 18-10-2008, 03:35
Instead of creating a new thread i'd like to ask if in 8/10 psi boost range on T2, is it normal to have red hot color on the exhaust manifold (first time i saw it in the night condition), seems dangerous to me what about your advice?
thanks
Old 18-10-2008, 09:14
i found that if you go to high on gain, then you get the boost creeping over your desired psi, i use 16% gain, then set the psi to what you want.
