Old 02-01-2010, 12:26
Default S13 Roll Cage
'think it would fit a '12 ?
Before anyone moans, yes it's more for the lulz but it's not-fia so doesn't weigh as much and my s12 will be going down the track route so it would be in keeping.
Old 02-01-2010, 19:41
Draconis's Avatar
Draconis Draconis is offline
Well, from what I'm aware of, it wont fit directly. I would suggest taking out your interior and fitting it in but I am sure you will have to do some amount of modification to make it work right since the interiors are a bit different but overall, decently similar.
Old 02-01-2010, 20:33
paulsilv's Avatar
paulsilv paulsilv is offline
Would be interesting to see how far off it is and how much it needs to be modified to fit.
May be a cheaper route to getting caged than a bespoke item.
Old 04-01-2010, 12:18
old-and-rusty's Avatar
I know that the s13 is a little bit wider (on the outside) than the silvia. But not too sure about the inside. However, when i was modding an s13 dash to fit the s12, I had to cut about an inch off each end of the dash to make it fit . So the s13 cage will probably be a bit too big for an s12. Hope that helps a bit .
Regards,
Ian.
Old 15-01-2010, 08:04
doski's Avatar
doski doski is offline
looks like i will be in luck, might have got a s13 cage to modify to fit the s12 in a couple of weeks thanks to apex performance's stupidity
Old 15-01-2010, 09:08
tell us more matey
