Old 07-03-2010, 20:36
irish s12's Avatar
Default Tyres for everyday driving
Just looking for peoples opinions on the tyres they have tried.
I've a set of Toyo proxes t1r's on the car at the moment and they are total rubbish.They have to be the most over rated tyre ever,brutal wet weather performance and not really that good in the dry either all in all pure crap.
I've been selling tyres for a while now and the ones that people allways buy again and can't really fault are Uniroyals so I was thinking about getting a set of them instead.
They are good value too,anyone tried them?
Old 08-03-2010, 00:38
i found t1-r's very good when i had them a few years back. There only a midrange tyre . im using Bridgestone potenza;s at mo. they came on the car, there alrite. nothing special either
Old 08-03-2010, 22:01
irish s12's Avatar
I find them pretty bad to be honest and in the wet they are lethal.
Old 08-03-2010, 23:48
what size on what rim width are you using?
Old 09-03-2010, 00:47
irish s12's Avatar
215 45 17's on 7.5" rims
Old 09-03-2010, 10:50
a few of our guys in the Roadgoing classes have used T1-Rs for sprints/hillclimbs and found them pretty good to be honest. They do, like most tyres with a reasonably low treadwear indicator rating, suffer from overheating if given death! once the surface is overheated the oils dissapear and the surface hardens appreciably. The only way to get rid of this is to remove a couple of mm of tread depth. this must be done without heat, i.e. natural wear due to normal driving road miles, or have the tyres 'shaved' my a motorsport team. the difference is huge.
some tyres, not sure about the Toyos, have different shore hardnesses or rubber throughout the tread block depth. The first few mm are harder as the tread blocks move around more when new and full depth, creating more temp in the block. when the tyres become worn down to near the tread wear indicator bars, the rubbers softer to compensate. Thats why a lot of racers that have tio run road tyres buy brand new tyres and shave 5mm of tread off before running them
the rubber also ages too. If the tyres are a couple of years old and yet barely used, they still wont be market fresh. Heat/cold cycles and UV light affect the aging hugely.
Tyres that have seen a lot of arc/mig/tig welding (ie stored in a workshop where lots of weldings done) will age the surfaces that are exposed. On a std road tyre the effect isnt as bad as on racier rubber (R888s, Yoko AO48Rs etc and especially slicks/wets) but still will affect the tyres performance markedly.
