Old 28-10-2010, 11:10
Default Rebushing Rear Arms
Hey guys I'm trying to rebush my rear arms. Burnt out the rubber and smacked out the core but I've been fighting the sleeve ALL FRICKING MORNING!! and the little twat just won't come out. All I'm doing is burring the edges and generally making a mess of the arm itself. That damn collar is supposed come out isn't it ? :grumpy:
Old 28-10-2010, 14:22
Take the arm to garage and use a press
Old 28-10-2010, 15:33
I work at a garage and we have a press but OMG is this thing fighting me
Incidentally it's a z31 arm so I REALLY need to not screw it up
Old 28-10-2010, 16:13
if they are the same as the s12 sleeves, and you are using poly bushes, then you need to leave the sleeves in, otherwise use an hacksaw blade carefully cutting along the inside lenght.
Old 28-10-2010, 19:49
uh.......'k......
maybe I can get oversized polys or something.....
Old 02-11-2010, 22:06
Okay after some research it looks like removing the OEM rear trailing arm bush shells was probably a bad idea Apparantly over size bushes aren't going to happen but hopefully a local machine shop can whip up some replacement shells.
In the mean time I've been playing with the Nolathane site and I see the Z31 300zx bushes cross-over with N13/14 Sunny front lower wishbone which I can get locally ie; not the other side of the world. Also the quoted bush dimensions will fit without the shells but I'll just see what happens.
edit: actually that can wait for now I've just spent over £100 @ Bilt Hamber
