Old 29-03-2007, 21:14
Beany-s12's Avatar
Default engine rebuild
i was gonna do a det conversion but time money and a serious lack of motivation means it's gonna have to wait till next year!
so new plan is to rebuild 1 of my et lumps! should have det pistons and rods comin next week and already got the following; s13 throttle body, s13 injectors, k&n cone filter, ally fmic, t25, lightened balanced flywheel, s13 exede organic clutch. will be getting walbro 255.
so any1 know other easy and low budget bits i should try and get hold of?
would like a ported head, cam and vernier but funds don't allow!
Old 29-03-2007, 21:53
Beany-s12's Avatar
sh1t i knew i forgot something! its currently running a standard sized exhaust pipe with the centre box removed and a stainless rear box off an s13, would this b good enough for wot i'll b running or will i really really need to go bigger and if so how much!
Old 29-03-2007, 22:15
The exhaust will restrict you but it will work for the time being. The standard centre and especially rear silencer are the biggest restrictions. Changine them will help a great deal alone. Go to 2 1/2" straight through with that setup Or anything upto 3" if you want to allow for future mods. Make one out of universal pipe and an overaxle bend from demontweeks for cheap enough
Other worthwhile mods are an electric fan. Grab one from the scrappy if on a budget. A piggyback ecu for the s13 injectors will be needed.
Other than that you've pretty much got it planned out very well. Glad to see your not neglecting the fuel pump
the piper cam doesnt really give you much power for money spent so i wouldnt really be too concerned/botherd about doing that unless your planning on using a t28rs or t3 etc
Old 30-03-2007, 09:44
Whilst your bottom end is in bits, take your rods/pistons crank and flywheel to ' Burton power ' and have them lightened/balanced. I priced it up ages ago and it was only about 140. They can also hone your block or bore it to suit!
Old 30-03-2007, 09:59
also might be worth seeing if the crankcase girdle from the DET will fit straight on to stiffen the block. take teh longer bearing cap bolts too
Old 30-03-2007, 19:19
Beany-s12's Avatar
cheers for the info chaps! i've already got a silvia engineering twin kenlow set up but forgot to mention it! haven't really got money for lightened and balanced bottom end coz gettin engine gaskets, rings and shells is gonna use most of wot i've got! i was under the impression that the s13 injectors would just run off the standard ecu! wot sort of piggy back system is needed or could i get away with an uprated pressure reg for a while until sorted?
Old 31-03-2007, 01:41
adzs12's Avatar
adzs12 adzs12 is offline
Forum Regular
Safc will do the job for you, can pick them up cheap enoough now of ebay and sxoc.
Old 31-03-2007, 01:43
Beany-s12's Avatar
might sound stupid but wot is a safc and is it much work?
Old 31-03-2007, 06:40
Its an electronic gismo that you wire in to certain point before the ECU which allows you to change things like fueling etc.
http://www.nissansilvia.co.uk/vbb/sh...highlight=safc
Old 04-04-2007, 21:49
Beany-s12's Avatar
right i've been lookin in to it and unless i find a really cheap safc it looks like it'll have to wait till after the rebuild! will i be able to use the s13 injectors without it or should i stick to the standard 1's until it's run in coz ideally i want to get it rebuilt and run in ready to use for jae then hopefully something will come up in the mean time!
