Old 27-05-2008, 20:59
rob turbo's Avatar
Exclamation massive fuel consumption
having reet problems with my new project, it seems to use FAR too much fuel when driving. booting it you can actuly SEE the gauge dropping... bolted on a few mod's zorst, filter, IC. . no boost increase. is standard at 6psi..
any ideas please.. need this sorting urgently guys
cheers
Old 27-05-2008, 22:27
fuel pressure regulator i should imagine
Old 28-05-2008, 20:47
or AFM
Old 28-05-2008, 20:59
or a hole in the tank.
Old 28-05-2008, 23:02
good alternative suggestion........
Old 28-05-2008, 23:41
well, i thought i'd put some good input in, so many people forget the obvious, a hole in the tank is not worth over looking, its so simple to spot, but mine was the regulator. what happening with ya white det rob ? have you started a new project ?
Old 29-05-2008, 00:21
zxocmars zxocmars is offline
My n13 was sucking up 13 MPGs.
Turned out the hose from the tank was corroded, and more was pishin from there than was going through the inlet.
