Old 21-02-2006, 18:25
Dan Dan is offline
Dan is an unknown quantity at this point
Default s14 brakes.
Hey,
How easy / expensive / worthwhile is it to fit s14 discs and calipers to the s12? Only i've read about people doing it quite alot recently and would quite like the upgrade.
Ta.
Old 21-02-2006, 18:52
Default S14 brakes
I've got the FOUR pot calipers fitted to mine on standard size Silvia discs which are drilled and grooved 274 x 22mm. S14/Z32 discs are 280x30mm but won't fit anyways as the are a push on type and are 5 stud. Silvias bolt on from the back of the hubs so are different. I think you can fit them If you use S13 hubs though. I wanted to fit the 4 pot calipers but could not be bothered with the hassle of the discs. They definately make a hell of a difference though.
Old 22-02-2006, 10:56
Dan Dan is offline
sounds good, thanks.
