Old 15-09-2006, 08:54
Unfortunately it does seem the S12 gearboxes are a bit of a weak link, with about the same strength as the S13 ones.
I've look at bellhousing swaps before.
I haven't looked at the comparison behind the mk1 and mk2 bellhousing bolt patterns. But I'm assuming they're different. I am also assuming though that the mk2 shares the same bolt pattern as the s13 box
Get an S14 box. Get a wrecked S12 mk2 box (i have one)
Removed the bell housings off each, and bolt the S12 bell housing to the S14 box.
Then see where you stand with the props. You might find a mix of mk1 and mk2 props might give the required length.
Old 15-09-2006, 09:15
i used to use mk2 s12 boxes, but now use s14 boxes with s13 bellhousings. im pretty sure a mk1 bellhousing wont fit the s13/14 boxes. The s14 box with S13 CA bellhousing needed my propshaft shortening by 50mm, and moved the gear lever back 65mm.
Think the s12 mk2 bellhousing will fit the s13/14 boxes (but not tried it)
Old 15-09-2006, 18:51
Yes this is What Norris designs did on japsters s12
Old 15-09-2006, 20:57
doski's Avatar
doski doski is offline
yea if i can get the parts i mite give it a try and see what fabrication is needed if it looks like it mite work, just trying to get parts on the isle of man can seem somewhat difficult or expensive......
refering to the mark 1 gearbox with the short shifter from a 280z
http://www.club-s12.org/forums/index...+short+shifter
just trying to get hold of one is the prob
Old 15-09-2006, 22:38
i did have a 280zx shifter somewhere i ll have a look see if i can find it and pm you if i have any luck
Old 16-09-2006, 15:15
doski's Avatar
yea thanks mate
