Old 18-09-2006, 12:33
smoker's Avatar
smoker smoker is offline
Default water injection
Hi just wondered if anyone had fitted a water injection system to prevent detonation - I was thinking of making up something to spray water into the air intake when the boost pressure goes over say 6 psi..hopefully should allow me to run std. unleaded and more boost or is that a totally mad idea
Old 18-09-2006, 21:20
i doubt you will need water injection @ 6psi.
Old 18-09-2006, 22:25
http://www.silviagod.pwp.blueyonder....silviagods.htm
Have a look what silviagod did in the link above.it may interest you.
Old 18-09-2006, 22:49
Magnum's Avatar
Magnum Magnum is offline
Water is like nitrous it doesn't flow evenly through an Intake manifold. If your going to build a system build direct port like this. http://www.rbracing-rsr.com/waterinjection.html
Old 19-09-2006, 08:46
I had a water injection system then decided to sell it.
You only get benefit from it if you are really close to detonating.
Some people use it on a track for preventative measures, but its actually been shown to reduce power when used like this. But obviously reduce the risk of anything naughty happening.
Old 31-10-2006, 00:03
smoker's Avatar
Hi, thanks to everyone that replied !. The off the shelf systems seem really expensive so I think I will try to make something up with an old electric fuel pump, string and selotape etc....I might splash out a bit more if i can get my flooding engine problem sorted.Thanks again
