Old 05-12-2006, 21:56
Dez Dez is offline
Default L.s.d.???
Is there any company doing L.S.D.'s for the S12?
Mines a Mk2 i think (1988)....
Old 05-12-2006, 22:43
no but you can get a ATB from quaife
Old 05-12-2006, 23:22
And if you don't have £600 spare for a Quaife then you can use an S13 LSD with some other bits, for very little money.
Old 06-12-2006, 03:13
Dez Dez is offline
600?..... .....Thats over double what i paid for the car - S13 it is then.
If anyone who has used and S13 diff could post up some picks of it, plus extra
parts i need - i would really appreciate it.
Thanks
Old 06-12-2006, 09:31
Old 06-12-2006, 13:36
Sharas's Avatar
Sharas Sharas is offline
Cant the left output shaft be used from the s13/s14 diff?
Old 06-12-2006, 13:54
No because it makes the shaft too long, and it full compresses up the cv joints and it even pushes the swing arm outwards
Old 06-12-2006, 13:59
Sharas's Avatar
Got that, well i think that wount be a problem (first i need to make the car runing again , now thats bit of a problem)
Old 06-12-2006, 23:37
Dez Dez is offline
Cheers for all the info mate, couldn't have asked for more. Doesn't look too bad a job. Just one question - Instead of machining the left inner cv joint - could i not just use the cv off an S13 on S12 shaft?
Old 06-12-2006, 23:51
That was the same question by Saras in post 6, to which the answer is no because the shaft will be too long then due to the larger size of the S13 CV housing and shaft.
Of course if you wanted you could have the shaft shortened a little by a propshaft company such as recoprop.
