Old 12-01-2007, 23:15
Originally Posted by Paulpen
So is it best to run with it retard a few degrees ?
i wouldnt bother retarding the timing it will lower performance + generate more heat, the standard timing is 15deg + or - 1 deg. i used to run 17.5deg as it gave better off boost performance but i never use less than 97ron fuel
Old 12-01-2007, 23:23
Standard timing will be fine and it will run normal unleaded for long distance commuting, If you intend on putting your foot down or are running a modified setup then use super unleaded. Also Shells new v power contains valve lubricant which is good
Old 13-01-2007, 14:12
Paulpen Paulpen is offline
Paulpen is an unknown quantity at this point
Cheers then chaps
Old 13-01-2007, 16:03
i thought you ran on ronnie corberts adz
Lol yeah i do but thats our secret fuel, you can buy a bottle of ronnie corbet additive from your local motor factors, just say ronnie barker recomended it
Old 13-01-2007, 18:10
Frank's Avatar
Frank Frank is offline
Frank is an unknown quantity at this point
maybe next week a buy some toluene, like to know if there will be any nice difference when adding it to 98 octane
I can get it for cheap, 1,20euro/liter, thats cheaper then ron98 over here
