#11
does anybody make standard diameter discs that are thicker?
Nope but I would suggesting getting the discs I linked to above which are 296x30, and use R33 calipers.
Of course if you converted to S13 hubs and coilovers for the front this opens up a new world of brake and suspension choices.
R33 calipers.... are fitted on which car?
I find all this brake lark confusing, sorry!
#15
I think the 296mm brakes I linked to uses R33 GTS skyline calipers. You could use S14 or Z32 calipers but anything larger than 280mm than they need to be offset with brackets.
Ok I'm getting this now, lol!
I need: R33 Front rotors modified for S12 hubs Pair 296mm SnS R32/R33 Caliper mounting kit to R30/31/910/S12 Pair including bolts Pair Skyline R33 Calipers And once I get hold of all those bits, I have everything I need?
if you got the discs the same size as the s14 ones, but those that take bells, i could get the bells made up. deamon tweaks list them.
If you were to go to the hassle of making bells then get 310mm discs.
what is a bell?
If they are just modified discs a machine shop could remachine the centres to bolt to the S12 hub.
