Old 09-02-2007, 00:28
Beany-s12's Avatar
Default think i've broke somethin
took my dash out the other day to fix my heater, found the broken wire so all was good! putting my dash back in today i thought i'd better check all my dash lights worked (which they do) and all i could hear was gurgling from the back of the car which sounds like the fuel pump is running backwards and blowing into the tank and the car won't run
any ideas
Old 10-02-2007, 01:17
Beany-s12's Avatar
got in it today nd all was good again poxy motor
Old 10-02-2007, 01:20
lol probably was just flooded mate
Old 10-02-2007, 02:11
Beany-s12's Avatar
na hadn't even turned the engine over just put ignition on to check lights work and the fuel pump started making random noises and when i turned the engine over the noises got worse then this morning it was fine again!
maybe it was just all a dream and all the late nights and work shop fumes r starting to effect me in some wierd way!!!!!!!!!!!!
Old 10-02-2007, 02:53
Lol or maybe your pump is dodgy? Id look into this a bit further mate as the last thing you want is the pump packing up when your driving.
