Old 16-09-2007, 14:48
Ronin's Avatar
Ronin Ronin is offline
Silvia Driver
Question What's this wire
Basically as the title says what is this wire in my grubby mitt where does it go or is it spare?
Any help would be appreciated.
Old 16-09-2007, 15:49
there are a few unused wires around that area that are for Air con, it maybe one of them
Old 16-09-2007, 16:13
Ronin's Avatar
Silvia Driver
Have just changed the head I have one grey multi connector spare that I knew would be and this wire which I'm not sure about looked every where tried it on a few bit it looks like it might connect to but no luck, just need to make sure it is spare and not something important.
Old 16-09-2007, 17:28
Struggling to see which one your holding to be honest, but it might the temperature gauge wire
Old 16-09-2007, 19:10
Ronin's Avatar
Silvia Driver
If it is where does it plug into as I have looked but not found anything that looks like it would plug in to.
Old 16-09-2007, 19:22
Its to the right of the yellow plug as pictured
Old 16-09-2007, 19:39
Ronin's Avatar
Silvia Driver
Cheers I'll take a look next time I'm with the car.
Old 16-09-2007, 19:43
it looks a bit to big for the temp gauge, unless its the photo, temp gauge is the a small spade connector on mine, well it was on the blue mk1, but that din't have a cover over it, i'll look at mine in the morning.
Old 16-09-2007, 20:17
Ronin's Avatar
Silvia Driver
I have been looking for a spade connector to plug into it as it is of that size.
Old 16-09-2007, 20:26
that will be the one that 30psi mentioned then, its on the left side of the thermostat housing, tooked away.
