Old 13-02-2008, 02:22
WM-S12's Avatar
WM-S12 WM-S12 is offline
Exclamation Clutch problem
Only today after a long trip I noticed my clutch goes in fine but sometimes it gets stuck just above where the biting point is.
Then occasionally it'll pop back to normal on either the two factors, one being letting it do it by itself or secondly tapping at the clutch pedal with your toe. ( i.e it doesn't sit level with the brake or accelerator pedals and makes a annoying thumping noise 1-2 seconds after changing gear <<< sometimes it just gets stuck )
I'm guessing something to do with the clutch but the clutch is only just 2 years old, it's not a con thing about the car is it. That the clutch tends to go every couple of years. ( Just frustrating knowing I might have to hike on foot over 2.5 miles in a day and at bloody after midnight in Scottish weather )
If anyone has a relative idea on what's wrong then fire them on, but my last clutch cost £215 supplied and fitted....so any help knowing where to look than my local garage would be a big bonus.
Cheers
Old 13-02-2008, 07:08
Speedycougar Speedycougar is offline
Speedycougar is an unknown quantity at this point
Get a few member(s) from here to help you?
RWD clutches are so easy to change it is ridiculous.
Matthew
Old 13-02-2008, 23:58
WM-S12's Avatar
currently I can shift through all 5 forward gears but reverse just won't go in and I'm not shoving it in as first time I tried it did that nasty grinding noise so I just push parked my car up for the night.
I'm not sure if mines a Mk1 or 2 anyone who knows the difference lend me a helpful tip ( 1987 E-reg ) Also is it a hydrolic clutch or cable? Can't exactly tell in the dark and without any jacks or ramps on me at the time.
Might necessarily not be the clutch itself as my peddle is getting stuck almost right down now yet it's still able to shift through the gears without any clunking or grinding bar reverse.
I'm going to take it to a local garage I know well 2moro, to see if they can help tell me what's wrong ( I'll have to get slagged for not buying the owners r33 skyline instead I got an s12 ) any help again will be welcomed.
Old 14-02-2008, 06:04
that will be mk2, you have the bigger bumpers, and the longer front grill bit, the change over year was 1986 there abouts.
s12's have a hydrolic cluch.
i think i would suggest cluch itself, i think all the forwad gears have synchro, but reverse wont.
Old 14-02-2008, 12:42
WM-S12's Avatar
Thanks for that info umpkin. Just about to take the car down to the garage and shine some light on the situation, will let you know what they say as you might be correct.
Old 14-02-2008, 13:48
WM-S12's Avatar
well that didn't help much, found out the possible reason for the sticky clutch peddle. It's either leaking fluid from the small reservoir or it's either the slave or master cylinder that's gone. ( couldn't get the car up onto ramp as they're fixing my neighbors mk3 supra with a new exhaust so I just left it down there until 5pm were I'll call and check if they had time. )
Old 14-02-2008, 13:54
Other than hydraulic problems, I would say clutch release bearing is knackered (normally comes as a 3 piece kit when you buying clutches).
Matthew
Old 14-02-2008, 14:19
WM-S12's Avatar
garage called, lets just say fluid goes in.....the slave cylinder takes a pish.
Exact same thing that happened to my old 316 beamer. Garage just called again, he ordered one up but it won't be here until monday ah well.
Old 14-02-2008, 15:35
Dont let them rip you off for the part, it's under £30 for a new one and 20 minutes to fit it and bleed the system
Old 14-02-2008, 17:15
WM-S12's Avatar
It's £40 supplied and fitted so I can't complain at that.
