Old 11-02-2008, 15:51
Paul Smith Paul Smith is offline
Paul Smith is an unknown quantity at this point
Default My CA18ET won't fire please help????? I'm New
Hi i hope you can help i have recently purchased a car with a ca18et engine fitted i believe from a bluebird turbo. She was running and broke down one day. I have an ok knowledge of engines but not particularly familiar with the ca18et. From what i have done so far she will turn over happily all day long but she doesn't appear to be sparking i have had the plugs out and i can see no spark. I was wondering whether it may be the ignition coil.
Or are there common faults with the engine to change first????
Please help
Paul
Old 11-02-2008, 17:06
Dr Silvia's Avatar
ello et welcome
s12's use a fairly straightforward ignition system, i can't think of anything you'd want to point the finger at outside of the normal sequence of tests. don't buy new items yet but try another plug on the lead then swap the lead out etc.. until you get something
Old 11-02-2008, 17:10
I tried two different leads and 2 different plugs straight from the ignition coil and neither sparked?
Could this be leads still or plugs ?
Old 11-02-2008, 17:25
Dr Silvia's Avatar
most common cause of my silvia not starting was plugs covered in coke
take the dizzy cap off and examine the contacts; if they are dirty buff them clean with fine emerycloth/fine abrasive paper, if they're mangled [unlikely]then replace. test this by checking for conductivity from dizzy kingpin lead across to htlead pins while turning engine by hand.
if you have a multimeter put it on 20v range and over primary windings of coil see if you get 12v; otherwise maybe a spare bulb likea fog light?
Old 16-02-2008, 18:32
Most common fault is a bad earth on the coil
This maybe a rare one but check that there is a 12v feed to the distributer.
I dont know the wiring diagram in my head but i know i lost this feed on my et once i put in a new one via a switched relay.
Old 18-02-2008, 03:05
definitely check the coil is earthed OK, it's earthed to the body where it bolts on, and it can rust there a lot.
is that Paul "drifty skyline" Smith?
Old 24-02-2008, 19:36
sorry for the delay in replying, thanks for the advise.
I was looking today, the coil i have now cleaned up but still no spark i have checked that fuel is coming through. It is pumping in to the chambers i think there was a lot of pressure behind the fuel when i undid the hose.
I was wonder how the is setup do these engines have a crank position sensor ???? if so any pics, if not what do they use.
any other ideas would also be a great help.
anyone one got a spare ignition coil plugs leads and distributor laying around that all work for sale???????????
Old 24-02-2008, 19:40
zxocmars zxocmars is offline
There is a Crank angle sensor, but not sure that would be your problem
I'm no expert by any means, but if the CAS was out woudl it not still spark, but out of sequence?
Might have a spare one somewhere
Old 24-02-2008, 19:42
i figured that if it was broke it wouldn't tell anything to spark???
Old 24-02-2008, 20:14
I'll dig around for a spare in the week
