Old 28-02-2008, 20:54
old-and-rusty's Avatar
Originally Posted by Paul Smith View Post
Hi thanks for the response the s12 lump isn't in a silvia or bluebird so i'm not sure where they would have put the fault screen, is it attached to the ecu?
....LOL.... Sorry for the confusion. As Martin says the ECU is the unit I was talking about (which you can use to carry out self diagnosis).
Regards,
Ian.
Old 29-02-2008, 18:53
Paul Smith Paul Smith is offline
Paul Smith is an unknown quantity at this point
if you have a distributor as well how much do you want for the distributor, would you be able to check it definitely works aswell, sorry to be a pain.
The ca18et lump is in a nissan micra k11.
Old 29-02-2008, 18:56
You will need a bluebird distributor.
Has the engine ever ran properly in the Micra? Could be a wiring issue? Have you got a proper fuel pump running off of the ECU?
Old 29-02-2008, 19:13
yeah it was running but broke down one day.
Old 29-02-2008, 20:02
yeah the coil is good mate.i'll pm you a price.
Old 01-03-2008, 20:20
would the distributor fit?
