well drove the s12 yesterday and everything working, took seats out today to do some work to it and started it up to get a bit of heat, so working away i looked at the dash and nowt was working, no oil press, temp or rev's?
gave it a rev no difference, only thing that seems to be working is the petrol dial. also the battery light is staying on but belts are fine. you think it could be a fuse/wiring from taking the seats out??
well thanks for all the interest but there done
i had a problem with some of the guages and it turned out to be a fuse.
Check the fusible links by the batter under the black lid.
I had this problem with my MK1 and the wire had corroded by the connector. Hope this helps. |
What was wrong Andy, and how did you fix it?
Might come in handy if anyone else has a similar problem |
