#11
Try Jack@Turbo Repairs Blackpool 01253 407464 as long as yours is serviceable he can recon it for about £250 all in inc collection/delivery. He can make up any to your spec and can make a T2 hybrid ie with bigger compressor which I had and makes loads of difference. Good thing about the hybrid is that it fit a standard engine/pipes
http://www.turborepairs.com/parts.html
Yeah. Adz did a spot on job when her did his. Marked everything up and torqued the shaft nut correctly, Even then it only did a few hundred miles. Ebay kits just are not precise enough
#13
found a local place for £300 exchange so will go for that one, getting the turbo out went ok up until one of the metal coolant pipes snapped! will probably get another made locally as cant see nissan having one, thanks for help all
#14
F$%k mine does this too, I just thought it was just the zorst coz its blowing right next to it, bet my seals have gone too.
Got more soul than a sock with a hole |
#15
could of saved yourself £50 with Turbo repairs!
