having reet problems with my new project, it seems to use FAR too much fuel when driving. booting it you can actuly SEE the gauge dropping... bolted on a few mod's zorst, filter, IC. . no boost increase. is standard at 6psi..
any ideas please.. need this sorting urgently guys cheers
fuel pressure regulator i should imagine
![]() Quote:
or AFM
or a hole in the tank.
![]() Quote:
well, i thought i'd put some good input in, so many people forget the obvious, a hole in the tank is not worth over looking, its so simple to spot, but mine was the regulator.
what happening with ya white det rob ? have you started a new project ?
My n13 was sucking up 13 MPGs.
Turned out the hose from the tank was corroded, and more was pishin from there than was going through the inlet.
