got a company offering to make me up a braided turbo oil feed, i just need the specs, (lenth, dia, bolt sizes at both ends)
going on a mk2 (1986) with a t25 turbo, anyone know the size so i can get it ordered? |
no one got any ideas? or a old dead feed that we could send them as a template?
If you've got a mk2 silvia just use a 200sx oil feed pipe get them on ebay, you need the metal screw in bit from the 200sx block I think.
Just do a search on here and you'll find your info. |
if its s13 then i can get him to make a decent one cheap
On the Mk1 it's by the oil filter on Mk2 it's on the turbo side, if you've got an early Mk2 it may have the early block so will need a turbo line made up as can't use a 200sx one.
I paid about £25 to get a decent braided one made up by a local company. Cheers |
anyone got a pic of were it should be on a mk2 so i can check my block, got 3 blanks on the turbo side that i can see atm...
if its there it wont be blanked it should have a pipe coming out of it to the turbo, if its mk1, it wont have a hole, the hole on the mk2 is behind the power steering pump.
they took the turbo apart kept the exaust side on, plated the join between the intake and exaust side, bolted the lot back on and blanked everything off, i'll have a look behind the pump for it, |
Try Hose Solutions. Got them to supply all the braided hoses for my T25/28 Turbo for my S13. They where really helpful as I had to have a different connection for the Oil to turbo feed, & longer hose for the water return to block pipe.
I intend on doing my S12 when I get a chance. Daz |
