grind that center section out mate, or it will end up through the turbo,they allways crack.
as shaun says, they all do that, yours is quite a good one TBH, seen them with a lot more missing. Just tidy it up with a dremel and it will be fine
are you sure thats still usable, looks to me like its cracked right through to the outside, not just between the seperator, would need a pic of the other side of that crack.
you may be right there mate, din't see that earlier.
