Old 06-03-2006, 22:15
GWtaylor GWtaylor is offline
GWtaylor is an unknown quantity at this point
Default Bottom end shell
Would a bottom end shell gone on No4 piston mean a new engine if not what would need replacing i.e full new crank
Old 06-03-2006, 22:19
i've got 2 good spare engines if need be.
Old 06-03-2006, 22:21
It would depend on how far it has gone. If the car was run with a bad knocking shell then chances are the crank and the conrod could be damged. If it was only a slight rattle it may be posable just to replace the shells only.
You would need to find out a bit more infomation and inspect the damage.
Old 06-03-2006, 22:22
Whats the milage and what kind of price
And how hard are they to swap
Old 06-03-2006, 22:23
the bloke said it's quite a rattle on it
i once swaped a Rover 25 engine by myself in 6 hours if that means anything lol
Old 06-03-2006, 22:42
i'll check the milage in the morning,ones mine and perfect on a auto and had no thrast at all, the other is my nieces boyfreinds s12 that i'am stripping at the moment, i've took it steady today and nearly got it out in 2 hours, i've just got to get it jacked up to get the down pipe of.both start first turn of the key. i'll find a price for the engine, i'd like to keep my auto in one piece for a while and maybe go on holiday in it as it does lots more to the gallon than mine.
Old 06-03-2006, 22:44
i got the engine out my mk2 last weekend in an hour before breakfast
Old 06-03-2006, 22:46
there ya go, easy job
Old 06-03-2006, 22:50
omg i was expecting a cocky answer.
I had the fact that the engine had only been in there for 4 months on my side though(no siezed nuts and bolts) and that me/adz and Dr silvia have done 7 or more s12 engine removal/changes in less than a year between us.
Being rwd and in a nice big engine bay there very easy engines to remove.
