Hi, i'm planning an S13 coilover suspension conversion for my S12.
For the front i think it's the S13 balljoint, spindle/hub carrier & hubs but i have no idea what i need to convert the rears, anyone on here done this? Also, i'm planning on fitting skyline brakes front & rear. i'll obviously have to redrill the discs with 4x114.3 pattern, i'm assuming the calipers will just bolt onto the s13 spridle/hub carrier as this is a common upgrade for S13's Any advice would be appreciated
custom front coilovers, -40mm rear springs, de-spoilered, Bailey dump valve, induction kit, mocal sandwich plate with oil cooler, OMP deep dish steering wheel, unknown jap 14x8" slotmags from 1976 |
For the rears you can fit Z31 parts. Bc Racing do a kit that consists of S13 fronts and Z31 rears for about £550. Theres some on ebay at the moment.
http://www.club-s12.org/forums/index...howtopic=18411 |
As far as i know yes.
Try doing some research, the answers are out there. Alot of parts are exchangable between the S12 and Z31 |
yeah i've heard, only prob with z31 rears is i can't find any coilovers for them, that's why i want to convert the car to S13 allround as there are always used sets of S13 coilovers available on ebay
hi
here is the link to a French forum topic for swap conversion front ![]() http://www.clubs12france.com/forum/v....php?f=4&t=752 for the rear brake, you can swap the rear brake Z31
You won't get coilovers per se on an S12 (or Z31) because the spring and dampner are seperated. You will only find lowering springs (possibily with adjustable seats) and adjustable dampners.
edit: The front is fairly straight forward for a competent tech. It's the rear, and the excessive tyre lean (negative camber) whixh is the real ball breaker.
There's a mk1 escort in ppc mag with full S13 running gear complete with the rear multi-link suspension (subframe 'n' all). I fancy some of that, and I reckon I could do it with help on the fabrication side of things, but is it rally worth all the work ? Probably not.
