Old 04-08-2011, 11:25
Jost joshing there our Shaun
Old 04-08-2011, 11:55
the metal tube for the platform is 50mm high, by 4mm thick and about 90mm diameter, then just grind a circle for the top out of some 4mm plate, the threaded tube is from rally design's its about 100mm long and if you use a 9 inch spring, then you can get the stock hight of around 12 inch and you can adjust it down by about 2 1/2 inch.
Old 04-08-2011, 17:59
thanks mate for that i rung rally designs today its about £100 to do it + p/p
what weigth are the springs ?? i would like hard ride as its a track car and low !!!
so not standard heigh
Old 04-08-2011, 20:18
they do them in all flavours matey, i used 315's on the front, then just checked the difference in the manuel between front and rear.
Old 06-08-2011, 00:24
paulsilv's Avatar
paulsilv paulsilv is offline
SOLD
I'll have 2 please
Copyright ©2000 - 2024, Jelsoft Enterprises Ltd.
