Old 17-09-2011, 03:50
bish bish is offline
bish is an unknown quantity at this point
Default electrical fault HELP
my s12 silvia has now been in the garage for 3 MONTHS !! it ll started with no spark at the plugs, an auto electrician said it was the power transistor/coil pack amplifier which i ordered from JAPAN and it still didnt work !!, ive put another distributor in along with a new coil pack, even managed to find someone with a silvia who kindly let me try his ecu, power transistor, distributor and coil pack off a running car and it still wouldnt fire, the suto electrician has given up and so has the mechanic, they told me to do the unthinkable and SCRAP the car, ive owned my silvia for 21 years and its been well looked after and the bodywork restored, if anybody has any ideas please let me know !! IM DESPERATE
Old 17-09-2011, 07:47
Hi where about are you
have you tested the loom and checked your earths
dose it just turn over or try to start
Old 18-09-2011, 02:39
Have you tried to read the fault codes from the ecu?
Old 18-09-2011, 19:11
tim murphy's Avatar
can you check power to the coil if you have power from it work forward or back if not a good mate told me this every problem has a solution: . cheers
Old 20-09-2011, 13:08
tim murphy's Avatar
hi just wounder hows the car going . have you check the crankshaft senor out not working no spark. cheers.
Old 24-09-2011, 17:49
the dizzy loom must be faulty. the s12 dizzy has an internal cam angle sensor which picks up top dead sensor.Get your guys on it.look at the wiring diagrams on the pdf downloads
or firstly yourself, check the 12v feed to the DIZZY. manually add a supply from the battery. i bet the bastid starts.
