Old 17-05-2016, 10:45
UmBongo1 UmBongo1 is offline
UmBongo1 is an unknown quantity at this point
Default Windscreen Washers Not Working
So I took my Silvia for a run today and the front and rear washers have stopped skooshing water.
There is no noise from the motor or pump at all.
I think there is a leak from the bottle and it may have destroyed the motor.
Thoughts and advice appreciated, please...
Old 17-05-2016, 20:59
tim murphy's Avatar
Hi more likely it is the motor check it on the battery there rust inside the motor cheers tim
Old 17-05-2016, 21:43
Hey Tim,
What should I check, exactly?
Old 18-05-2016, 21:34
tim murphy's Avatar
Hi i took my washer bottle off and ran two wires from the battery to the washer pump if it works will buzz if no buzz no good can buy them easy from car shops or motor factors cheers tim
