Old 31-08-2006, 16:21
Redon Redon is offline
S12oc Newbie
Redon is an unknown quantity at this point
Default Redon
Why has my turbo (S12) 1.8...suddenly started whistling like a real high pitched scream?
Redon
Old 31-08-2006, 16:42
one of the gaskets has probably started to blow, keep driving it hard and it will soon sound like a tractor
Old 31-08-2006, 21:33
or the turbo blades have been damaged
Old 01-09-2006, 10:52
or could be an air leak possibly from that very thin pipe that goes from the joint at the brake booster to the Boost sensor near the turbo
Old 04-09-2006, 20:42
screaching is normally the turbo gasket just before as previously said it blows the gasket out and sounds like a tractor lol .
Try nipping up the 4 nuts up before she blows with a 13mm spanner
The nuts normally come loose because when the turbo has been changed the washers with tabs are not refitted before the nuts . ( they have tabs on them that bend down round the nut to stop the nuts coming loose)
