Old 06-09-2006, 09:39
bigtim's Avatar
bigtim bigtim is offline
Thumbs down manifold change
Having to change my manifold as it as a crack in it and i'm not looking forward to it really but needs must.
Going to leave the turbo were it is and just get the manifold off on its own.
Ive got my mani and turbo gaskets sorted and the wd40 ready.
Had some expert advice off Shaun again as usual but Any more tips welcome.
Wish me luck as I've never had to do it before
Old 06-09-2006, 09:55
Smile Manifold removal
Watch you oil and water feedpipes to the turbo they can be a bit fragile if old. Apart from the fiddley nut at back of manifold it'll be easy !
Old 06-09-2006, 10:18
Is it the standard one ? If it is matey I would take off the tubby/manifold together as its less hassle and will take you alot less time
Old 06-09-2006, 10:19
bigtim's Avatar
cheers dude,
thats why im going for the leave turbo were it is option and just take the manifold off.Spose ive got 4 shite nuts to turbo to fiddle with but it seams the better option.
Ill see how it goes.
Old 06-09-2006, 10:29
tim, are you going to get your ass outside and do the job then lol, no use sat thinking about it .
Old 06-09-2006, 11:34
your a lucky chap if you have lasted this long without ever having to remove it before
Old 06-09-2006, 11:38
bigtim's Avatar
well its took about 40 mins and its nearly off,one bolt to go at the back on the bottom of the manifold all turbo and other bolts are off,bit of a roll.
came in for a cuppa.
Old 06-09-2006, 13:16
Told you it was a fiddley bolt !
Old 06-09-2006, 14:39
I got a special spanner for that pain in the arse nut
Old 06-09-2006, 16:06
bigtim's Avatar
sorted,one bolt is looking dodgy as its not solidly tight and keeps turning which is a bummer its tight but wont lock tight and i can see the bolt coming out.
I guess this first pic is why the turbo gasket was blowing,or though this is at the back and the leak was at the front gasket was in two.
This pic is why i changed the manifold in the first place as it was leaking out this crack on top,
All off,oil is from dizzy seal which is on the agenda next
All done,dodgy bolt is top left as you can see its a bit longer,just hope all the others keep it in check.Doesn't seem to be blowing anywhere when i fired it up so fingers crossed.Biggest pain was getting the locking tabs done up one still needs doing.
Big thanks to Shaun for answering his phone every time i called and my 13 and 14mm stubby spanners which with out there help non of this would have been possible.
