anybody have white instruments in theyr S 12? or have a layout file on the computer?
![]() I want White instruments I'm sure someone else does too:P
Nissan Silvia S12 1985 FJ20E 2.0l 16v. DOCH |
not come across any white dials yet
just badly made aluminium dial surrounds i will have a look at the possibilities later this morning
okey!
thnx alot!
ok gotta admit i forgot all about this till an hour or so ago
anyhow i've stripped a dash unit apart and got the dials out ![]() the guages for boost/fuel and oil/water are simply two thin sheets of acrylic however the speedo and tacho dial faces appear to be printed acrylic.. this means that witha rub down with fine wet n dry will leave you witha clear plastic plate which you can then have re-printed. The warning lamps are coloured by removable sheets of couloured acrylic. im going to try an find someone who can print these up as im interested now i've got it all apart i think a signwriter will do the job.. fingers crossed...
Nice job hope they can do it
i'd be interested in a set ant.
so would i
but if you have a scanner on your computer you can scan it? I think I can do some white layouts in photoshop if you give me a scanned picture.. if I make a whole white layout, we can lay it on top of the old one and light it up with UV lights
will look neat I think
then itll be printed on paper and any lighting effect applied to it will become grainy. I do have a scanner but in the interestts of keeping the ciomputer simple its gone back in the cupboard for the time being.. i will see if it fits on the scanner bed later, for now its the morning after the night before
haha I see:P but if you print it on matt photo paper the results are pretty good..
