Old 22-10-2006, 13:22
Dr Silvia's Avatar
good point i hadnt considered the new papers you can use at home now as i dont have the technology for that myself.
is there any visible grain in the paper when you hold it up to the light?
also how much light penetrates from a low wattage bulb as found in the dashboard??
Old 22-10-2006, 20:34
if you do scan it, would you mind putting a link on here so a few of us could try it with our own personal changes etc, cheers, looks like a great idea.
Old 22-10-2006, 21:23
henrix's Avatar
henrix henrix is offline
henrix is an unknown quantity at this point
the point of the UV light is that it only light up the white layout if you leave the numbers black it will not glow.. the UV light is placed in front of the white layout (not LEDs behind) therefor you dont need the light to penetrate sorry if my english is bad.. let me know if you dont understand. BTW if you bye a GOOD matt photopaper iy dont have any visible grinds
(the UV light I'm going to use is the same kind you will find in your "modded" computer)
Nissan Silvia S12 1985
FJ20E 2.0l 16v. DOCH
Old 22-10-2006, 21:40
these could also be used, as they say they are for dash lighting
http://www.maplin.co.uk/search.aspx?...u=y&DOY=search
Old 22-10-2006, 21:42
henrix's Avatar
yep but they will fit behind the instruments
I'm thinking more like this
http://img204.imageshack.us/img204/8...eterlys5sl.jpg
Old 22-10-2006, 21:55
RichardK's Avatar
RichardK RichardK is offline
Forum Administrator
Any good sign writer will do that for you if you provide the JPGs!
Old 22-10-2006, 22:02
Dr Silvia's Avatar
those look more like blue led's to me.. uv reaction is purple...
Old 22-10-2006, 22:09
henrix's Avatar
I know it was the best I could find.. but too use a UV pipe if you know what I mean? hehe
btw that link didn't work
Old 23-10-2006, 20:59
Dr Silvia's Avatar
Default progress...
the tacho and speedo fascia wont fit on my scanner in one go i'm going to have to re-download photoshop and see if i get lucky with it
fingers crossed
Old 23-10-2006, 21:09
RichardK's Avatar
Forum Administrator
Ant,
if you need it i can post you Photoshop 8 CS CD
