  #15
Old 03-11-2006, 02:22
smoker's Avatar
smoker smoker is offline
Thanks everyone for the help, especially adz and pukka ..I got a gunson's colortune and timing light and they seem to work ok, didnt think they did a pressure gauge too.
I managed to find a T piece and an old air pressure gauge and measured the fuel pressure as 35 psi (idling) and 42 psi at WOT so the pressure regulator is working some as far as I can tell but i'm not sure what the spec is
Car flooded again today and I had to take the plugs out and blowtorch them...not going to be very convenient carrying a torch with me incase the engine floods . Tryed removing the fuel pump fuse and flooring accelerator but this didn't work
So far I have : -
Checked timing 18 deg BTDC
cleaned AFM with white spirit and paintbrush
changed engine temp sender
adjusted valve clearances
checked earths at coil and swapped rotor, cap & leads
I tried adjusting the idle CO with the screw on the AFM but it doesn't seem to affect the idle and just turns and turns.....do they go clockwise to weaken the mixture ??
