Old 04-11-2006, 21:52
Il be suprised if it is the ecu but fingers crossed for ya mate
Old 06-11-2006, 19:07
jakezx's Avatar
jakezx jakezx is offline
jakezx is an unknown quantity at this point
i have tryed two ecu's but still no luck. i have had the spark plugs out seems that there is no fuel coming through to them. so i think may be fuel pump but the ecu says every thing is fine think may have to ring a garge as need the car back on the road
Old 06-11-2006, 20:59
i'm sure last time i was round i could smell/hear the fuel coming thru into the engine bay, so maybe its the injectors? ive got a few you could try....
Old 06-11-2006, 23:54
Mate this is starting to ring bells, i had a very similar problem if not the same in the summer. Check all the wires going into the connection blocks down by your afm as i had to replace part of the ecu loom as i found one wire " white if im not mistaken" that had corroded and had broke off which was causing the injectors not to fire.
Old 07-11-2006, 01:48
smoker's Avatar
smoker smoker is offline
surely if the injectors are working you would hear them 'clicking' and you can check the pump is working by disconnecting the hose at the fuel filter and letting it run out into a bucket with the ignition on. I think you have to crank the engine with the fuel pump fuse out to relieve the pressure..i didn't and got covered in petrol which is not nice
Old 07-11-2006, 02:02
Sounds so much like what happened to mine i would be totally lost if its not what i suspect, check them wires and plugs mate
Old 07-11-2006, 08:13
kennyboy's Avatar
kennyboy kennyboy is offline
Default Wire down near the afm
I agree with Adz on this one , i know i dont Say much lol !! but when i we were about to change my ecu and everything over there was a problem with the white or white and black wire being perished before we even started.
Worth a wiggle of the wire as your trying to start it , or strip the loom back for a good look at it .
Good luck with it .
Old 11-11-2006, 18:59
jakezx's Avatar
dont worry and thanks for all the help i have had it fixed it was to do with the spark plugs 2 where not givin a strong enough spark and ht leads damaged but it is running now the mobile mech did not have a clue what he was doing o well runnig aweet again
Old 11-11-2006, 19:06
None of them stupid mobile mechanics know what there doing half the time especially when it comes to these, i remember when pukka had one out and he was a complete burk, we fixed it in the end anyway so he kinda wasted some money there but we was baffled at the time and wasnt as experienced as we are now
