Old 12-11-2006, 12:44
cool whatve you done chassis wise to get all that power down?
Old 12-11-2006, 12:58
i might underseal it
Old 12-11-2006, 22:11
Decent suspension and some decent size & compound rubber is all thats basically needed
Old 13-11-2006, 00:59
Originally Posted by adzs12
GT28R at 20-22 psi
that's pushing the turbo way beyond it's limits, you'll be heating the air up so much you may as well not run an intercooler
Old 13-11-2006, 01:03
Sounds awesome
265bhp Sounds good. It means you dont need to uprate your clutch to a paddle.
Im aiming for the same level as you by the sounds of it.
why would you need a paddle for over 265?
Old 13-11-2006, 01:08
Ok then 19 psi will do me
Old 13-11-2006, 10:45
safe limits for long term usage. I base this on past experience with the type of driving we do.
Also my comment is based along with the other componants, it is overall a good stage to get to. Next stage would be complete engine internals,Bigger turbo still, 444 or larger injectors and with all that would have to come a paddle plate.
Old 13-11-2006, 13:11
I'm going to use an organic clutch (RPS Max Street) for over 350bhp, there's no need to use a paddle on a road car really, all you'll do is damage your flywheel and clutch cover, you have to slip a clutch for driving in traffic and slipping a sintered metal puk on a steel flywheel eats at the surface like you wouldn't believe. i got through a clutch plate cover and flywheel in 3k. Yeager killed 2 in 6 weeks
Old 13-11-2006, 14:38
Japster's Avatar
Japster Japster is offline
I have to admit - That's why I don't drive mine in traffic if I can help it! - I have the 5 plate Exedy paddle, and it's awful for traffic driving - I can literally feel the abuse to the clutch! )
Still, they transmit really well, so I'd not go back to normal if I can help it.... ...having said that, I think that a lot of my pulling away problems are from the gearing being very long in conjunction with the Z31 diff's final drive (i.e. 55-60mph in first, 100-ish in second, 135-ish in third), etc... great for top speed, but awful for pull-off!)...
Still, I'll be able to comment on this fully once my car has been "S13Eater'd", as he's kindly sorting me out a reconditioned master clutch cylinder, as mine if leaking (The slave cylinder was originally leaking, so I doubt the clutch has ever been running 100% as of yet (was slipping like an absolute b*stard at JAE, before Pukka and Shaun bled it, which fixed it temporarily)... - Once again, cheers guys!
Old 13-11-2006, 17:38
How much do those clutches go for Danny? And where from. I had not heard of them before.
