cheers mate,
There is mixture of 14mm nuts onto studs and 2 17mm bolts!! the bugger is 17mm that i cant get to. Gonna cut a 17mm combination in half and have a go that way!!! Gonna have fun getting the oil and water pipes back on.....cant wait. |
Yeah ive seen 17mm bolts used before but you should find that its still the same size thread so helicoiling for the std studs wont be a problem if you decide to do them
If you have a mk2 engine, then find the piece that firstly screws into the block from either a turbo bluebird or an S13 200sx. This then allows the use of the S13 braided oil feed.
