Old 25-11-2006, 14:03
s12Rob's Avatar
s12Rob s12Rob is offline
Default thicker metal head gaskets
does anyone do one for the s12?
Old 25-11-2006, 18:49
Fl EBAY.com or .com.au
Old 27-11-2006, 11:31
http://cgi.ebay.com/ebaymotors/CA18E...spagenameZWD1V
Old 27-11-2006, 11:50
Why do you want a thicker head gasket? What are you trying to achieve?
Old 27-11-2006, 14:12
s12Rob's Avatar
thicker gasket so can run more boost and will be stronger
Old 27-11-2006, 14:23
The CA18ET is already 8:1.
It don't need to be any lower unless you want ridiculous boost.
Old 27-11-2006, 14:50
i ran 32psi with the stock gasket.
Old 27-11-2006, 18:48
smoker's Avatar
smoker smoker is offline
Thicker gasket would upset the cam timing and also harm off boost performance and fuel economy imho
Old 28-11-2006, 09:40
The cam would be advanced by less than a degree with even a 2mm gasket, so its not anything significant.
The off boost power would be reduced.
Old 28-11-2006, 23:35
Dez Dez is offline
All of the above plus the fact that the boost depends on a fine balance between the comprssion ratio and the volume of air been induced into the cylinders. Yes the engine will take in more air, but what you gain you'll lose automatically becase the compression ratio will be far less. Sorry mate but you'll acheive nothing.
