#22
hadnt thought of that, but yes you could well do if running it direct to the actuator. my actuator signal goes from the plenum, thru an Audi TT boost solenoid then to actuator and is controlled by the ecu. Your Omex new should be able to it too. makes it possible to alter boost infinitely thru the rev range and removes spikes.
