Old 28-11-2006, 23:35
Dez Dez is offline
All of the above plus the fact that the boost depends on a fine balance between the comprssion ratio and the volume of air been induced into the cylinders. Yes the engine will take in more air, but what you gain you'll lose automatically becase the compression ratio will be far less. Sorry mate but you'll acheive nothing.
Old 28-11-2006, 23:43
Beany-s12's Avatar
surely the increase in boost pressure that he's lookin to gain from doing this will over compensate the loss of compression!
Old 29-11-2006, 00:50
but the ET is already a low compression engine, at 8:1 it's lower than a lot of turbo engines of the same era, newer turbo engines seem to be running a lot higher CR. the Audi/VW 1.8T is 9.5:1 for instance. IMO you don't need to go lower than 8:1.
The engine I'm building will have re-worked combustion chambers but I will skim the head to compensate
Old 29-11-2006, 08:52
i thought the ET was 8.5:1
Old 29-11-2006, 09:34
Nope its defo 8:1.
Old 29-11-2006, 12:43
no, the DET it 8.5:1 the difference is almost entirely down to the larger chamber volume of the head, the pistons aren't dimensionally much different really
Old 29-11-2006, 23:25
smoker's Avatar
smoker smoker is offline
I skimmed 40thou of my head when I rebuilt so i reckon my CR is 8:5 - 9.0:1. No problems with detonation so far, i plan on using water injection if I hear any when I up the boost further.
Old 30-11-2006, 02:00
I make that about 8.7:1
