Old 28-11-2006, 23:43
Beany-s12's Avatar
surely the increase in boost pressure that he's lookin to gain from doing this will over compensate the loss of compression!
Old 29-11-2006, 00:50
but the ET is already a low compression engine, at 8:1 it's lower than a lot of turbo engines of the same era, newer turbo engines seem to be running a lot higher CR. the Audi/VW 1.8T is 9.5:1 for instance. IMO you don't need to go lower than 8:1.
The engine I'm building will have re-worked combustion chambers but I will skim the head to compensate
Old 29-11-2006, 08:52
i thought the ET was 8.5:1
Old 29-11-2006, 09:34
Nope its defo 8:1.
Old 29-11-2006, 12:43
no, the DET it 8.5:1 the difference is almost entirely down to the larger chamber volume of the head, the pistons aren't dimensionally much different really
Old 29-11-2006, 23:25
smoker's Avatar
smoker smoker is offline
I skimmed 40thou of my head when I rebuilt so i reckon my CR is 8:5 - 9.0:1. No problems with detonation so far, i plan on using water injection if I hear any when I up the boost further.
Old 30-11-2006, 02:00
I make that about 8.7:1
Old 30-11-2006, 12:19
Yeah I make it 8.65:1 with 83mm pistons, and with 84mm pistons 8.85:1
Old 30-11-2006, 12:56
do you know the exact chamber size? I had to reverse engineer the calculation to work that out.
Old 30-11-2006, 12:58
I used reverse technology as well to provide a combustion size of 64.61cc.
