Old 19-09-2006, 09:41
I never knew se did a rear coilover kit
Yeh, I've seen it twice
Old 19-09-2006, 09:43
Originally Posted by s13eater
i'am going to try and get hold of some bigger discs b4 i put them on , if no one can match anything up,i'll just get some disc without the centers and get some bells made up.
You're best to remove the disc and reassemble the hub. Then try to find an S13 disc, wack it on then see if it is central in respect to the caliper. If it is then you could use redrilled S14/300zx discs easy enough.
You may have to use longer wheel studs though, depends on the discs and your wheel & nut combo
Old 19-09-2006, 09:59
i'll have a go, as i have a old z32 disc in the shed, cheers martin.
Old 19-09-2006, 10:01
It will need redrilling to 4 stud first though
Old 19-09-2006, 10:24
what i'am thinking is,looking at them side by side, the center of the z32 disc will need machining out about 6mm, this will allow the unbolted center of the s12 disc to be placed onto where the z32 stud holes are, then i can turn untill hopefully i find a undrilled space for all 4 holesto be drilled, then this will still mean that i'll need spacers for the calipers, but it could all go tits up, if it takes the calipers to close to the struts.
Old 01-12-2006, 13:37
Old 01-12-2006, 13:39
just a pic and update of the finished items.
Old 01-12-2006, 18:18
They look superb mate, how much they set you back?
Old 01-12-2006, 18:47
£160 with vat and postage for the teins, £100 for both coilover kits and i've put new kyb's in
Old 01-12-2006, 19:42
very sexy. Top work
