Well if that solves the problem, there's a 95% chance the main relay is sticking.....
Very very common problem. Try it anyway, you can do no harm by checking a relay. I'm not sure myself where it's located but, it should either be close to the ignition or beside the ecu. It'll probably be different to the rest. |
Thanks for the replies
. I tryed a push start with the key out and no start so I guess the ignition switch is ok. Does sound like a relay sticking I can hear something click under the speedo sometimes when I switch off . Trouble is It looks really difficult to get to without putting my back out so think i'll check the relays under the bonnet..seems to be alot so should be fun
