Closed Thread
Old 05-12-2006, 21:56
Dez Dez is offline
Default L.s.d
Is there any company doing L.S.D.'s for the S12?
Mines a Mk2 i think (1988)....
Old 05-12-2006, 22:43
no but you can get a ATB from quaife
Old 05-12-2006, 23:22
And if you don't have £600 spare for a Quaife then you can use an S13 LSD with some other bits, for very little money.
Old 06-12-2006, 03:13
Dez Dez is offline
600?..... .....Thats over double what i paid for the car - S13 it is then.
If anyone who has used and S13 diff could post up some picks of it, plus extra
parts i need - i would really appreciate it.
Thanks
Old 06-12-2006, 09:31
Old 06-12-2006, 13:36
Sharas's Avatar
Sharas Sharas is offline
Cant the left output shaft be used from the s13/s14 diff?
Old 06-12-2006, 13:54
No because it makes the shaft too long, and it full compresses up the cv joints and it even pushes the swing arm outwards
Old 06-12-2006, 13:59
Sharas's Avatar
Got that, well i think that wount be a problem (first i need to make the car runing again , now thats bit of a problem)
Old 13-02-2007, 17:41
124's Avatar
124 124 is offline
124 is an unknown quantity at this point
I thought I might add that in the Vlsd the V stands for viscous. Viscous diffs are basically a single open diff with some friction plates that heat up a fluid which then engages the other half but only if it gets hot enough. This system works well if used for an extended period of time or if warmed up before use (eg small burnout) but generally, when driving around normally it wont do anything if you try to drift straight up. So it is a cheap alternative to a proper lsd but its like anything you get what you pay for.
Old 13-02-2007, 19:27
i cant see how this set up would be reliable as you are using 2 different types of joint on the same drive shaft. CV which isn't supposed to move and a lobro joint which is designed to move. i cant see the CV joint lasting very long
Closed Thread
