Old 16-12-2006, 19:45
The S14 conversion isn't worth it really unless you use thicker discs. The braking effort will be pretty much unchanged. I bet that Wilwood conversion up there feels magical. When I've worn out the Z32 discs I will go to 310x32mm discs from Apex Performance.
S12's discs are only 22mm thick. Coupled with calipers what dont do a good job of asborbing heat unlike the larger S14 caliper, they are more likely to fade. This is where the real issue lies. The braking force on std discs is reasonably ok, its just there ability to withstand continuous use which is a big issue. Even with the Portfield pads and new discs, I questioned their resistance to fading after a hard lap of the romford ring road.
Old 23-12-2006, 16:24
is that the romford ring in your sig mart lol.
Old 23-12-2006, 19:07
Na Dartford Tunnel apparantly
Old 31-12-2006, 18:54
i'd go for the s13 set up any time.
